Author Topic: please name this 1.8T re-circulating valve  (Read 2450 times)
Offline cullygti
Re: please name this 1.8T re-circulating valve
« Reply #10 on: 07 May 2012, 20:33 »
this fred is pointless  :grin:
« Reply #11 on: 07 May 2012, 21:07 »
Compbrake or ebay Forge copy
Offline paultownsend
« Reply #12 on: 08 May 2012, 18:29 »
will i honestly see a difference moving to a forge 007p?
Offline topher
  • Administrator
  • fully functioning
« Reply #13 on: 08 May 2012, 18:33 »
only if the one you have is borked. push the piston up and put your finger over the small vac nipple on the top. it should hold some pressure then snap shut when you take your finger off. even if it doesn't do that it may just need servicing/re-greasing.
Offline Chris#101
« Reply #14 on: 08 May 2012, 19:12 »
Likes been said if the.diaphragm and spring in the.valve are ok you'd be wasting your money.
The duty of a recirc valve is so simple, your just paying for the brand
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
