Author Topic: Sump guard  (Read 2686 times)
Offline badboybunty
Offline Paul81
  • 2002 GTI Turbo
Re: Sump guard
« Reply #11 on: 08 May 2012, 00:53 »
Is the sump the lowest point under the car?
Is that what scrapes the square speed bumps?
Mods - Tinted windows, Mk8 Polo aerial, BBS RS2 alloys, -40mm Koni springs, Bilstein b4 shocks, VRS steering wheel, anni roof spoiler, R32 front bumper, rear anni valance, R32 side skirts.
Offline thatwillis
Re: Sump guard
« Reply #12 on: 08 May 2012, 01:42 »
Yeah I've upgrated to the shallow steel sump. Quite inpressed with the kit i got from awesome, not too hard to fit ether. Having a sump gaurd isnt really going to protect your sump. If you hit it hard its still gonna take some impact.
Mine fitted
Offline Paul81
  • 2002 GTI Turbo
Re: Sump guard
« Reply #13 on: 09 May 2012, 13:42 »
Mine fitted
How much extra clearance does this give you?
Offline MrRogers
Re: Sump guard
« Reply #14 on: 09 May 2012, 16:25 »
Quite intrested in one of these myself. Do these sumps fit the oil level sensor? Or do you loose that option once its installed then have to code the sensor out via VagCom?
2000 Golf MK4 1.8 AGU black magic, Custom Code stage 1 remap, Forge 008, Simota Aeroform CAI, G60/VR6 Combo, Weitec GT Hicon coilovers, Golf GTI MK5 18" Monza style alloys, 10mm H&R spacers front + 20mm H&R spacers rear, OEM Polo MK5 aerial, Whiteline front ARB + Whiteline droplinks.
Offline Cummins20vT
Re: Sump guard
« Reply #15 on: 09 May 2012, 18:25 »
shallow sump win
sump gaurd lose
Offline thatwillis
Re: Sump guard
« Reply #16 on: 09 May 2012, 20:49 »
Only slightly more clearance about an inch, But most importantly the bottom is made of steel rather than aluminium.
You can get another version that has a fitting for the oil level sensor but don't seem to be able to find it.
Offline Paul81
  • 2002 GTI Turbo
Re: Sump guard
« Reply #17 on: 10 May 2012, 01:10 »
Willis - How do you take square speed bumps?
Does your new sump ever catch them?
