Author Topic: MK3 windows wipers  (Read 2024 times)
Offline Tonicpar
MK3 windows wipers
« on: 07 May 2012, 13:35 »
i have a mk3 gti 2.0 16v...but the front window wipers wont go on fast speed just intermittent.  any ideas on how to fix? thanks
There is always a future!
Offline Screech16v
  • MK3 20vt AGU
Re: MK3 windows wipers
« Reply #1 on: 07 May 2012, 14:37 »
Possible switch failure on the stalk
Offline mad4vws
« Reply #2 on: 07 May 2012, 15:13 »
as said by screech
Possible switch failure on the stalk or the  wiper motor is on it's way out. :grin: :wink: :smiley:
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline lewis85
« Reply #3 on: 07 May 2012, 16:26 »
Inave this problem on my e mk3 estate is it a big job to swap the stalk for a new one?
Offline Tonicpar
« Reply #4 on: 07 May 2012, 18:14 »
thanks
is that an easy fix?
Offline gasketface
« Reply #5 on: 07 May 2012, 20:37 »
Disconnect battery,remove steering wheel,unplug all connectors,remove screws holding stalk on,and refit in reverse order.Front wiper motor is simple to replace,never done a rear as yet on a Golf but imagine it's pretty straightforward.
Offline Tonicpar
« Reply #6 on: 08 May 2012, 19:39 »
Cheers for that. I'll try that. The wiper arm mechanism goes up but clicks straight back down. The wiper blades move when I push the arm up but just doesn't want to stay up. Pushing it down does the intermittent wiper. The wash works and rear wiper works fine. I don't want to buy or attempt to fix if it's another issue. Thanks everybody for your advise......I can be a muppet :grin:
Gavv8
« Reply #7 on: 08 May 2012, 19:55 »
There are days when i'd rather be a muppet than a human.. :sad:
Offline Tonicpar
« Reply #8 on: 08 May 2012, 19:59 »
You have made feel much better that there are other muppets out there  :grin:
Offline Tonicpar
« Reply #9 on: 16 May 2012, 22:19 »
new stalk fiitted everything works a treat!
cheers for help
