Author Topic: performance chip??  (Read 2862 times)
Offline b_boy02
Re: performance chip??
« Reply #10 on: 07 May 2012, 22:16 »
That's solder type I'm pretty sure, in which case it's a job for a ECU specialist, which for the price you might as well get a professional remap.
Do you have any idea if the chip on a 1996 16v is a push or solder type?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #11 on: 07 May 2012, 22:49 »
It should be push fit just like most of the 16v chips are (my 97 16v was) BUT there are several types so it's worth emailing the seller and he'll tell you if his are compatible with your ECU.
Offline Khare
  • The bear that khares
« Reply #12 on: 08 May 2012, 00:54 »
That's the best option. You will need to send him your ecu code.
Offline Ess_Three
« Reply #13 on: 08 May 2012, 08:26 »
ABF ECUs are all push fit, regardless of whether they are AE, BE or AB type.
..but gaining motorcycles.
Offline Dogbot
« Reply #14 on: 08 May 2012, 08:52 »
this brings me happiness & joy!! :grin:
« Reply #15 on: 08 May 2012, 09:09 »
Oh really, when I spoke to the seller of the chips albeit quite a while ago I'm sure he mentioned that there was a certain ECU used that wasnt push fit.
Offline Ess_Three
« Reply #16 on: 08 May 2012, 11:08 »
I've had all 3 types in the past and all were push fit.
Unless the cases had been swapped over?
Offline Khare
« Reply #17 on: 08 May 2012, 11:21 »
Doubt it. I'm pretty sure all 16v's and early VR6's and early 8v's were push fit.
I think the reason he wants different ECU codes is to program that chip to that ECU code.
Offline Screech16v
  • MK3 20vt AGU
« Reply #18 on: 08 May 2012, 19:02 »
Yep mine was push fit 97 BE
