Author Topic: engine conversion specialists????? where are they?  (Read 9608 times)
Offline steble
are there any company's out there that would do a 2.0 16v conversion on my mums mk1 gti cabrio?
looking to get an idea of how much it would cost, to save me the effort.
Offline Cummins20vT
Re: engine conversion specialists????? where are they?
« Reply #1 on: 09 May 2012, 20:41 »
lots of companys out there, how much you willing to spend.
Offline JamesS
« Reply #2 on: 01 June 2012, 09:38 »
If there is someone close by on the forum that has done conversions then it may be worth contacting them. If they have the time they will probably charge you half what a professional garage would charge. All I would say is source a well running complete car and engine, not just an engine. You don't want to pay a garage a load of money to fit the engine then find out it's junk or needs work. Good luck!
AEROSPACE GRADE CNC MACHINED VR6 KEYRINGS. ONLY £16.50 INC P&P.
http://www.mk2vr6.com/board/viewtopic.php?f=28&t=13053
Offline popleyruss
« Reply #3 on: 15 June 2012, 13:28 »
Engine and box 200-500
Manifold 150-300
Ecu defeat 100
Mounts 120-200
Looms gonna probably take a few hours so 100 150
Set aside 100 or 200 quid for little bits u may need
Just plain dubbin
Offline razla
Villa in Orlando, Florida, 10 mins from Disney! Pm me.
marcevs72
« Reply #5 on: 19 October 2012, 16:56 »
get hold of my mate dan at devon dub shack,this is an easy swap.
Offline JamesS
« Reply #6 on: 13 December 2012, 14:54 »
Another option would be a 1.8t. A BAM lump can be had for under 1k now and as standard it has 225bhp. Qpeng can supply an ECU with switchable map (225 - 260bhp) downpipe and all the other bits required.
If you are paying someone to do a conversion then I would spend a bit more and get a 1.8t, go on, DO IT!
Offline popleyruss
« Reply #7 on: 13 December 2012, 21:44 »
Pointless buying a bam any 20vt varient with a ko4 set up will make that power us if u stick with a agu code easy to wireing using the standard loom and ecu with a de imobalised ecu
Just plain dubbin
