Author Topic: lowered mk4 rubbing  (Read 1935 times)
Offline Starry
  • http://planetweed.co.uk
lowered mk4 rubbing
« on: 30 September 2003, 23:19 »
I drive a 1.8 t 1999 it is lowered 35 mm but for some reason it rubs on the drivers side ,the rubbing is comming from the driveshaft touching the antiroll bar. I did cut the bump stops down a bit but not much and it only happens on one side. Also there is a slight knocking from the same side over some bumps almost as if the top of the strut is loose but it's tight... ???
1.8T 200bhp/237lbft.r32 F/BUMPER/ MILLTEK TURBO BACK,WITH HI-FLOW CAT/REVO/BAILY DV30/FRONT MOUNT I/C
