Author Topic: New Pope smoke  (Read 1689 times)
Offline Mart8V
  • I really should know better by now.....
New Pope smoke
« on: 06 June 2005, 20:11 »
Hi guys,
Mate's 8V is popping white smoke at the moment and burning about half a litre of oil a month.  What is the problem and rough cost of sorting?  Has 143k on the clock and has been well looked after, no leak from the rocker cover to speak of.
He doesn't have the money for a new engine at moment, but hoping it is not that serious. :huh:
Cheers.
Offline BobbyT
Re: New Pope smoke
« Reply #1 on: 07 June 2005, 12:09 »
could be the head gasket, not sure of cost! 150 -200 quid maybe?  :undecided:
Offline Mart8V
Re: New Pope smoke
« Reply #2 on: 07 June 2005, 18:40 »
Was wondering about that, but apparently no sign of mayo under the filler cap.  Valve seats?
Offline Mr Blue
Re: New Pope smoke
« Reply #3 on: 07 June 2005, 20:16 »
i think white smoke means its burning coolant too
Offline Mart8V
Re: New Pope smoke
« Reply #4 on: 07 June 2005, 21:09 »
So that would indicate that the head gasket is on the way.....  will check under his filler cap again.  Thanks!
Offline BobbyT
Re: New Pope smoke
« Reply #5 on: 08 June 2005, 12:18 »
i had a nova once (no jokes please) there was loads of white smoke on start up and the coolent level kept dropping, no mayo though! but in the end it was the head gasket, had that replaced and all was fine!  :smiley:
Offline Horney
Re: New Pope smoke
« Reply #6 on: 08 June 2005, 12:40 »
Do a compression test to see if any of the bores are down. If two next to each other are lower than the others than a headgasket is the most likely cause.
Nick
Offline Mart8V
Re: New Pope smoke
« Reply #7 on: 08 June 2005, 18:56 »
Thanks for that, guys.  Will report back when matey has done further inspections!
Offline PeteMk2
  • Keeping things blue & fast since 1991
Re: New Pope smoke
« Reply #8 on: 13 June 2005, 21:21 »
Check the colour of the expansion tank as well. If it looks like chocolate milkshake then its head gasket time  :sad:
