Author Topic: Bad reception on am ,standard fitted radio-can it be improved?  (Read 940 times)
Offline jnielow
Hello all,
I was just wondering if there was any way I could improve the AM reception on my standard fitted radio?-if its the earth connection where is this located in the car?
Any help would be welcomed!
Thanks
Jason
Offline harlemex
I dont think you can fellar. The aerial is already amplified and grounded. If your other bands are okay then the only way to get better a.m. is to buy an expensive tuner unit or longer aeria,l or both.
Offline mattkh
Hi
Is the amplifier in the aerial, do you know ?
Offline harlemex
I am not sure.If you can get hold of a base, then unplug your current aerial and plug the new base into your radio directly instead of fixing it to the roof first(to check all is okay before pulling your headliner off). If the aerial base is amplified, then there will be a seperate wire with a positive feed going to it. (usually blue, but not neccassarily)
