Author Topic: Changing to g60 flywheel.. What uprated clutch to go for?  (Read 1255 times)
Offline gti_boz
As above.. What clutch shall I go for? Want it to be an uprated one..
What you recommend? Links would also be good? ;)
Offline lukeyyyyyyy21
hi mate there is a thread with this exact question started 2 weeks a go in this forum
http://www.golfgtiforum.co.uk/index.php?topic=227189.0
have a read through the thread. should answer the question. :)
« Last Edit: 04 May 2012, 20:08 by lukeyyyyyyy21 »
Offline navmk4gti
vr6 clutch
Offline gti_boz
I'm running quite abit of power do need sonthing to withstand abit of a beating :)
Offline navmk4gti
how much power are you running?? a g60 flywheel vr6 clutch set up can take quite bit of power.. and they are known to "never go".. so sure will be good enough unles your running like 300 bhp plus or something  :grin:
Offline gti_boz
Sorted then.. Not sure what I'm running after my meth kit is mapped in but not over 300 il go for the vr6 clutch then :)
Offline turbokid23
So wot clutch would u use then for 280??
Offline gti_boz
Which pressure plate do you use then? The g60 one or the vr6?
Offline navmk4gti
just buy complete conversion kit.. has all bits you need. just dont get off a dodgy ebay seller
Offline gti_boz
I've already got a g60 fly so don't want to buy the kit
