Author Topic: Vag com Readiness tab info  (Read 4631 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« on: 04 May 2012, 09:33 »
I just got a vag com cable off ebay and on the Readiness tab it says this -
Exhaust Gas Recirculation     Secondary air injection
Passed                              fail or incomplete
Oxygen sensor Heating         Evaporative emissions
Passed                              failed or incomplete
Oxygen sensor                    Catalyst Heating
Failed or incomplete              Passed
Air Conditioning                   Catalytic converter
Passed                              Passed
Does it also mean that one of my Lambda sensors is not working, I have no fault codes showing though  :huh:
Can anyone tell me what this means please.
Thanks
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Keithuk
Re: Vag com Readiness tab info
« Reply #1 on: 29 May 2012, 01:49 »
If you bought vag com cable off ebay then its probably using VCDS Lite or its a very old cable there should be error numbers with each of those errors can you post those?
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
« Reply #2 on: 29 May 2012, 06:57 »
Thanks for the reply,  :smiley: I will plug it back in later on today and post the numbers up
