Author Topic: Upper Gearbox Mount, what to get  (Read 1892 times)
Offline lukeyyyyyyy21
« on: 03 May 2012, 22:14 »
Dogbone mount went a while back. The upper Gearbox mount under the airbox is also fooked. Going to do when I do the clutch and flywheel. Had a look on ebay and Ive found non branded ones for as much as £28. Yet a racing spec one online for around £144!
Does anyone or can anyone reconmend one for me?
Polly a must on a mapped car?
What's the best one, and where from?
Offline Toby
  • Car - less
Re: Upper Gearbox Mount, what to get
« Reply #1 on: 03 May 2012, 22:53 »
i think dave_iow still has his ones for sale  :huh: upgraded ones!
Currently down under
Offline Rhyso
« Reply #2 on: 04 May 2012, 08:34 »
THS Performance mounts are  :cool:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 04 May 2012, 13:21 »
nope they are sold
As Rhys says THS are the ones to go for  :wink:
Offline Jin_C
« Reply #4 on: 04 May 2012, 13:30 »
An alternative I found to buying the whole mount is to replace just the rubber. Black Forest Industries do an insert which you can replace yourself. I think Regal Autosport import them. Although I've not used it so I can't comment on its quality.
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline Scott D
« Reply #5 on: 04 May 2012, 20:50 »
THS mounts are decent
Swapped a 2 month old genuine dogbone for a THS, instantly had better gear shift feel and more traction. Much less vibrations compared to polybushes as well.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline navmk4gti
« Reply #6 on: 04 May 2012, 20:54 »
r32 dsg mount is good not to stiff or soft had it on my maped agu.. poly bushes just break your back  :lipsrsealed:
avs parts do r32 dsg mount now for about 35 quid bargian i think.. or if you want to spend a little get the ths mounts rhyso recomended  cant fault them :wink:
« Reply #7 on: 04 May 2012, 21:37 »
Didn't mention that I replaced the dog bone with a oem one. it's the upper gearbox mount under the airbox that i need. :)
Offline navmk4gti
« Reply #8 on: 04 May 2012, 21:41 »
sorry my bad ignore me  :lipsrsealed:
id recomend ths ones too. ..if you got the cash. or replace with original oem ones  :wink:
Offline Rhyso
« Reply #9 on: 04 May 2012, 21:51 »
Yes and we've said to replace it with a THS Peformance mount.
It's not the upper gear box mount; its an engine mount  :wink:
http://www.golfgtiforum.co.uk/index.php?topic=112925.0
