Author Topic: Need some help regarding spacers stance :)  (Read 1809 times)
Offline vwkevgti
« on: 03 May 2012, 21:08 »
The golf has been off the road all winter its had a good tidy up sold my r32 rep wheels and now I have some bbs ch reps that I'm going to be fitting 215/40/18 tyres too I want to space the wheels but don't want any rubbing issues  so was wondering what was the best combo my car is slammed on coillovers don't mind winding it up abit to accominadate the spacers I'll be using hub centric spacers was thinking 20mm on the rear and 10mm on the front
I've got 215/40/18 tyres
Bbs ch reps et35
Lowerd on coilovers with ajustable drop links
The rear perches for coilovers are still fitted
I've looked in to this just wanted some advice if the above will fit
Thanks kev
Re: Need some help regarding spacers stance :)
« Reply #1 on: 03 May 2012, 21:13 »
They will fit fine and those spacers should also be ok.
Offline cullygti
« Reply #2 on: 03 May 2012, 21:16 »
spot on as wayne says  :smiley:
Offline vwkevgti
« Reply #3 on: 03 May 2012, 23:22 »
Thanks guys can crack on and get me stuff orderd and get the golf back on the road
Offline badboybunty
« Reply #4 on: 04 May 2012, 07:05 »
what j are the wheels ???
Offline vwkevgti
« Reply #5 on: 04 May 2012, 14:23 »
Not sure what you mean buddy can't see any kind of j rating on the box
Offline cullygti
« Reply #6 on: 04 May 2012, 14:24 »
how wide are they 7.5 inch 8 inch 9inch etc
Offline vwkevgti
« Reply #7 on: 04 May 2012, 14:39 »
Oh right if you measure the wheel on a flat surface there 9" wide
Offline badboybunty
« Reply #8 on: 04 May 2012, 14:41 »
Measure the entire width of the wheel. If it's an 8j wheel, it'll measure 9" across from outside of the bead to outside of the bead
it will be a 8j wheel then :smiley:
Offline cullygti
« Reply #9 on: 04 May 2012, 14:57 »
if they ar ch reps im assuming the will be 8" all round unless they are the staggered ones which will be 8"front and 9"rears
