Author Topic: Yet another problem..Brake bleeding  (Read 2156 times)
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
« on: 03 May 2012, 19:49 »
Right, well turns out earlier it was the rear hoses, so i've replaced both. But now i've bled both rear but i have no pedal?  its just going straight to the floor and it sounds like theres air coming out from the engine bay?
Can anyone tell me what the heck is  going on? 4 hours of frustration! Also, is there a specific way to bleed a GTi?
Cheers!  :angry:
Mk4 Gti - Gone but not forgotten!
Offline stfc_gti
Re: Yet another problem..Brake bleeding
« Reply #1 on: 03 May 2012, 20:20 »
There a "How to"for this, maybe rich can find you the link. Or you could search for it.
2002 1.8T GTI AUM, Standard (not for much longer)
Offline cullygti
« Last Edit: 03 May 2012, 20:29 by cullygti »
Offline Xtrhardcore
« Reply #3 on: 03 May 2012, 20:29 »
Brillian cheers  :wink: is that gunna be my problem ddo you reckon?
Offline cullygti
« Reply #4 on: 03 May 2012, 20:29 »
theres another there for you to try to  :wink:
« Reply #5 on: 03 May 2012, 21:33 »
Better to do it with a pressure bleeder
Offline Steve_PD
« Reply #6 on: 03 May 2012, 21:43 »
You must follow the correct sequence when bleeding the brakes. Even if you don't touch the front brakes they still need bleeding
Offline Xtrhardcore
« Reply #7 on: 03 May 2012, 22:27 »
Ok just pick up the gunson hydronic brake bleeder so will try sort tomorrow. Any tips on the reservoir? Does the cap have to be open etc?
Offline Steve_PD
« Reply #8 on: 03 May 2012, 22:41 »
Yes, as you have to keep the level at the top otherwise you'll end up dragging air through the system and risk blowing the seals in the master cylinder.
Offline Xtrhardcore
« Reply #9 on: 03 May 2012, 22:45 »
And how would you know if you've done that lol?
