Author Topic: slighty juddering and over revs  (Read 994 times)
Offline 1stevester1
« on: 03 May 2012, 19:32 »
hi carnt figure this one from cold its a bit jerky at low revs like its going to stall and also when i change gear it carrys on climbing a bit so change a 3k revs after clutch is in to 3.25k could it be maf or throttle body neads cleaning anny help would be great chears
Offline cullygti
Re: slighty juddering and over revs
« Reply #1 on: 03 May 2012, 19:36 »
it does sound like tb needs a clean wouldnt hurt to clean it and see how it goes mate  :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 03 May 2012, 19:36 »
check the vac pipes under the inlet manifold for leaks... and clean the throttle body anyway if it's never been done :tongue:
Offline 1stevester1
« Reply #3 on: 03 May 2012, 19:38 »
i was going to do that untill a little searching and somewhere saying if its not a cable throttle then you have to have vag com or something as it will run shocking
Offline navmk4gti
« Reply #4 on: 04 May 2012, 00:07 »
buy a 10 quid cable off ebay .. and vag com is free downlaod from rosstech (not full version but will do the job)
or if you want you can have my vag com cable for £6 posted as i have no use for it now  :smiley:
