Author Topic: diesel smoke!  (Read 3107 times)
Offline Luke1981
diesel smoke!
« on: 03 May 2012, 19:08 »
My vw caddy 1.9 sdi 2003 kicks out a bit of black smoke when I put my foot down!  I don't know much about diesels and I regularly see this happen on other vehicles.
It is not losing any oil and the coolant is spot on. The exhaust back box could do with being replaced though. The van starts perfectly first time!
Is this normal?
Thanks
Luke
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: diesel smoke!
« Reply #1 on: 03 May 2012, 19:44 »
Try some redex, that may help clear it out. Check for a boost leak on all of your IC pipe work as a small leak will cause smoke. However it is not uncommon for diesels to smoke under load...that is half the fun  :evil:
Offline Luke1981
Re: diesel smoke!
« Reply #2 on: 03 May 2012, 19:58 »
Cheers mate, will give redex ago  :smiley:
Re: diesel smoke!
« Reply #3 on: 03 May 2012, 21:58 »
Black smoke is a sign of overfueling, check the air filter is clean and then go for some fuel / injector cleaner.
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: diesel smoke!
« Reply #4 on: 03 May 2012, 23:50 »
Apparently the Forte stuff is the best, just reminded me to buy some.
