Author Topic: Boost gauge hose  (Read 3245 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Boost gauge hose
« on: 03 May 2012, 11:15 »
I bought some washer hose from halfords for my boost gauge as the one that came with it wasn't long enough. Is it is ok to use halfords washer hose, or will it split and crack?
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Re: Boost gauge hose
« Reply #1 on: 03 May 2012, 21:56 »
You would be better with silicone hose tbh.
I got mine (3mm) here: http://www.ebay.co.uk/itm/3mm-Silicone-Vac-Hose-Boost-Dump-Valve-RED-5M-/270418310425?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3ef62ff519
They do other colours as well.
Offline Chris.
« Reply #2 on: 03 May 2012, 23:36 »
washer will be fine tbh.
Click For Build Thread
« Reply #3 on: 03 May 2012, 23:40 »
Will it  :undecided: it does tend to go hard with age and crack.
« Reply #4 on: 04 May 2012, 07:43 »
Thanks guys, the hose that came with the gauge looks and feels more or less the same as the washer hose from Halfords, that's why I thought it would be ok to use  :undecided:
« Reply #5 on: 04 May 2012, 09:14 »
I guess it will be ok but I prefer silicone hose tbh.
« Reply #6 on: 04 May 2012, 09:43 »
ok thanks  :smiley:
Could you or anyone else tell me if the grommet to feed the hose through is next to a white box underneath the scuttle panel on the drivers side that already has a black cable going down into it which comes from the side of the bonnet.
« Reply #7 on: 04 May 2012, 10:46 »
Try the bonnet release cable grommet
« Reply #8 on: 04 May 2012, 12:49 »
Where is that, or could that be what I am possibly describing in my previous post.
Offline Chris.
« Reply #9 on: 04 May 2012, 22:03 »
Ive seen loads of boost gauges with what looks like washer fluid tubing in it.
