Author Topic: ahhh cutting out when i turn right.  (Read 1236 times)
Offline cooki2
« on: 02 May 2012, 23:39 »
Hi everyone I have had no internet so haven't been on here for a while, I have just completed a 1.8t engine.e conversion and when I turn right or hit a speed bump it cuts out but most the time because I M moving it bumps itself. I have been through all the wiring in the engine bay and inside the car going to all the relays and fuse box Nd can't find anything wrong, anybody had this problem before? Thanks mike.
Offline cooki2
Re: ahhh cutting out when i turn right.
« Reply #1 on: 05 May 2012, 00:47 »
Anybody had this?  :smiley:
Offline simon_709
« Reply #2 on: 06 May 2012, 08:14 »
Hi mate have you checked the battery ? Because I had a simular problem once and my positive was loose on the battery which caused the car to knock out.
My Golf GTi, RS4 reps 17", coilovers, tinted windows, De-cat and middle box removed with 3" oval back box, stage 1 Revo re map, G60 flywheel/VR6 clutch, HID kit, Forge 007p,
Offline lemski
  • 16v
« Reply #3 on: 06 May 2012, 10:48 »
I would go battery terminals as my mk2 us to knock the positive of while I was goin
Offline daz veedub
  • Operation 1.8t bolf
« Reply #4 on: 06 May 2012, 12:24 »
are all the lights etc on dash staying on when it does cut out  :undecided:
Offline cooki2
« Reply #5 on: 06 May 2012, 21:40 »
Hi I did check the terminals on the battery and were fine, the lights on the dash do go out, is there anyway the battery could play up?
Offline RnP
  • Audi S4 gone, looking for b5 rs4
« Reply #6 on: 07 May 2012, 09:57 »
I had this turned out to be the battery earth was loose as soon as I went over a bump connection was lost an power would cut
Offline cooki2
« Reply #7 on: 07 May 2012, 20:45 »
Checked all the earths in the car and engine bay but were all tight. Vag com won't bring anything up, ummmmm this is confusing lol.
