Author Topic: Leaking Fiesta  (Read 730 times)
Offline Mikester
  • Civic Type R
Leaking Fiesta
« on: 02 May 2012, 12:59 »
Afternoon,
My partner has an 04 Fiesta Petrol 1.25... Its on 80k and has rarely been serviced although runs surprisingly well. I thought i would check the water last month and i noticed that the expansion tank was empty... bone dry. I obviously filled it back up and topped it up once the air leaks went.
After one month i checked the water again and its back to empty. It took nearly 2litres to fill it back up to max. However the car isnt overheating. I have checked all the pipes and cant see a leak. I have checked the oil and cant see any """"mayo""" in it.
Any ideas of what would cause it to loose water that quickly? Radiator hole?
Mike
Offline barrym381
Re: Leaking Fiesta
« Reply #1 on: 02 May 2012, 13:04 »
run the car for a while and check the cap on the expansion tank an pipes see if the leaks only happenin when up to temp
