Author Topic: Im so fcuked off right about now!!!  (Read 2106 times)
Offline Adz Gti
  • Instagram - gti_adz
« on: 01 May 2012, 23:20 »
My passenger side window has its moments whwn it wants to go up, most of the time it goes half way n goes down automatically, today just about 10 mins ago it didn't want to go up so I just pulled it up slowly while pulling the button, anyone know what the problem is and how it can be fixed ?
Just Daily Dubbin
Offline thatwillis
Re: Im so fcuked off right about now!!!
« Reply #1 on: 01 May 2012, 23:25 »
Pretty extreme amount of anger for a window not wanting to go up...
Offline Nino
« Reply #2 on: 01 May 2012, 23:25 »
Check these common faults buddy, im sure theres something there about falling windows....
http://www.golfgtiforum.co.uk/index.php?topic=38557.0
Current - MK6 GTi Edition 35
Offline Adz Gti
« Reply #3 on: 01 May 2012, 23:31 »
i've read about that window problem but my window hasn't fallen it doesn't want to go back up
Just Daily Dubbin
Offline km
« Reply #4 on: 01 May 2012, 23:32 »
not sure if this helps because it's not a golf, this happens in my mates corsa when it reaches the very top, i have to tap the button slowly, so it nudges a little every time..
Offline thedirge
« Reply #5 on: 01 May 2012, 23:50 »
if its bugging you that much take it to a garage.
Offline Scott D
« Reply #6 on: 01 May 2012, 23:57 »
might be worth taking the door card off and using silicone spray on the window runners before buying regulator repair kits.
had the same problem a year back and did the above - no problems since.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Adz Gti
« Reply #7 on: 02 May 2012, 00:01 »
cheers scott, first advice and will try it after i figure out where to buy silicone spray from lol
Just Daily Dubbin
Offline cullygti
« Reply #8 on: 02 May 2012, 00:01 »
i got the up rated metal reg clips and mine was doing it a few weeks ago then it was fine but i got a dodgy door module could it be this i wonder  :undecided:
Offline Adz Gti
« Reply #9 on: 02 May 2012, 00:03 »
wait wouldn't wd40 do it and btw cully mate just told me a window module from dealers is £80  :cry:
Just Daily Dubbin
