Author Topic: Drop in Turbo pressure 17705  (Read 2715 times)
Offline Joewb84
« on: 01 May 2012, 16:08 »
Hey Guys,
I have a fault code reader and I am getting the code 17705 when I check it.  I have checked all of the hoses that I can see and can't see any obvious splits.  I understand it is common for the standard Bosch DV to fail. I eventually want to get a remap done and was going to change to the Forge DV and figured I would do this now and see if it gets rid of the fault.
Does anyone know of a good website or garage / shop in the Bromley (Kent) area that I can get the Forge from?  The ones I can find all seem to be £100+ for the part alone.
Cheers,
Joe
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: Drop in Turbo pressure 17705
« Reply #1 on: 01 May 2012, 17:57 »
It could also be a software bug in the oem mapping. The early 2000-2001 AUM had this bug.
For the 007p you can try one of the forum sponsors  http://www.midlandvw.co.uk/forge_motorsport.html
They might do deals for the forum.. :wink:
http://www.golfgtiforum.co.uk/index.php?topic=229392.0
Nick
 01455 617233
Offline Joewb84
« Reply #2 on: 01 May 2012, 18:14 »
Thanks for the reply. Mines a 52 plate. Those links look useful.
Offline Joewb84
« Reply #3 on: 03 May 2012, 16:47 »
I have found a place locally to fit a Forge recirc valve on Saturday.  Hopefuly this will sort the fault.  Fingers crossed!
Offline Joewb84
« Reply #4 on: 05 May 2012, 15:31 »
Got a Forge recirc valve fitted at Sanspeed in Bexleyheath for £80.  I've erased the fault code and will see if it comes back.  If it does I will get a smoke test carried out and probably get the software update as well.
Offline Keithuk
« Reply #5 on: 28 May 2012, 11:00 »
VAG Error Code: 17705
EOBD II Error Code: P1297
Fault Location:
Pressure Drop between Turbo and Throttle Valve (check D.V.!)
Possible Cause:
Malfunction Indicator Lamp (MIL)(K83) ON.
Power Loss.
Leaking Hoses and/or Pipes between Components.
Boost Pressure Control Valve (N249) faulty.
Diverter Valve faulty.
Throttle Body dirty.
Possible Solutions:
Check Hoses and Pipes between Components.
Check / Replace Boost Pressure Control Valve (N249).
Check / Replace Diverter Valve.
Check / Clean Throttle Body.
Perform Throttle Body Alignment.
Special Notes:
Did anyone install an extra (wrong) dump valve?
When found in the NAR (North American Region) 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather Valve.
If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
