Author Topic: Beading with epoxy resin?  (Read 2465 times)
Offline Gabriel2202
« on: 01 May 2012, 14:01 »
Hi, Has anyone beaded an aluminium pipe with an epoxy resin?
Such as this - http://jbweld.net/products/jbweld.php
Thinking of doing it on an intercooler pipe as i dont have a beading tool, but will it hold the boost?
Cheers  :smiley:
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline danny_p
Re: Beading with epoxy resin?
« Reply #1 on: 02 May 2012, 00:54 »
if JB weld holds  it holds.
you can stick sparkplugs in if needs must with that stuff  but i wouldn't recomend it for that application.
there are several motorsport approved botches for holding boost hoses on  these include
PU  adhesives  such as tiger seal -   rough up the metal pipe  first  apply sealant  and push on and clamp hose   it'll never blow off again you'll never pull it of ether
Vulcaniseing rubber solution - pritty much as above  but with some effort you'll get it off but it sets faster.
various anerobic bonding agents -  as above  but actualy made for the job
easyest way i find is just to run a bead of weld around the pipe
all the VW's have gone bar 1.
Offline tshirt2k
  • Been there...Done that...
« Reply #2 on: 02 May 2012, 08:51 »
Problem with ali, its harder to weld. If you went with stainless you could cut small ring if pipe and expand them, slip them over the pipe and tack on with a mig welder.
I tried running a bead around the pipe before and it wasn't as neat.
Mk3 ABF 16VT Megasquirt V3
Offline Gabriel2202
« Reply #3 on: 02 May 2012, 11:33 »
Thanks for the replies  :smiley:
Problem is I'm trying to integrate the forge map sensor pipe with my existing intercooler pipe work. Both are aluminium so was thinking I'd have to use silicone joiners....
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline Gabriel2202
« Reply #4 on: 02 May 2012, 11:35 »
Thanks for the advice
I might try the tiger seal on the map sensor pipe then as I won't ever need to take that off (fingers crossed)
Golf IV 1.8T AUM
Golf V GT TDI PD170
