Author Topic: Heater matrix  (Read 7794 times)
Sugar79
Heater matrix
« on: 06 June 2005, 09:33 »
OK, I am getting closer to solving the overheating problem, my heater matrix!! there is hot water going in and NO water coming out!! haven't a clue how this could happen unless the garage who changed my cambelt messed with my cooling system!!
Are heater matrix easy to replace or would it be easier to get someone to power flush it???
Offline topher
  • Administrator
  • fully functioning
Re: Heater matrix
« Reply #1 on: 06 June 2005, 09:39 »
bit of a mission to replace.. just the time it takes, it isnt really difficult but need to be patient :grin:
as for blowing it out... last time i tried that with a pressure steam cleaner (on my old xr2 when i was 18) there was a loud pop and a lot of water in the footwells, managed to explode the matrix :laugh:
Sugar79
Re: Heater matrix
« Reply #2 on: 06 June 2005, 09:56 »
hmmmm dunno if i wanna try the power flush now lol, do you know how much a new matrix costs mate??
Offline topher
  • Administrator
  • fully functioning
Re: Heater matrix
« Reply #3 on: 06 June 2005, 10:00 »
about 40 squid .. eurocarparts website is down at the mo so cant check,  but im sure stuart will do you a discount if you ask nicely :cool:
Sugar79
Re: Heater matrix
« Reply #4 on: 06 June 2005, 10:07 »
yeah i put a message in the deals n discounts board for a lambda sensor FPR hasnt got back to me yet  :cry:
Offline topher
  • Administrator
  • fully functioning
Re: Heater matrix
« Reply #5 on: 06 June 2005, 10:10 »
flutter your eyelashes and show a bit of leg.. works when i do it anyway :laugh:
Sugar79
Re: Heater matrix
« Reply #6 on: 06 June 2005, 10:17 »
hahahaha ok *sets up webcam* lol  :laugh:  :laugh:
Offline GTI EDITION (aka LTD)
Re: Heater matrix
« Reply #7 on: 06 June 2005, 10:59 »
Are you sure it's the matrix as the mk4 water pump impellors have a habit of coming loose therefore causing overheating . Did they change the pump when they did the timing belt ?  :huh:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Sugar79
Re: Heater matrix
« Reply #8 on: 06 June 2005, 11:38 »
no i didnt have the water pump changed, but i really dont think it is the pump, my dad checked over the car yesterday, we changed the thermostsat first as some pipes where getting hot and some was cold, tested the theromsatat in hot water and it worked fine, so under some more investigating and Gurgling noises coming from the back we found the pipe which goes to the matrix was red hot and the exit pipe cold, so we pulled the exit pipe off with the engine running to find no water coming out the matrix.
I think its blocked with something, which is stopping the water circulating, a small amount of "muddy" looking water came out but then it stopped, the rest or the pipes have that red G12 collant in it which is clear. all very odd as ive had no work done to the car other than the cambelt really.
Offline topher
  • Administrator
  • fully functioning
Re: Heater matrix
« Reply #9 on: 06 June 2005, 11:45 »
makes sense, matrix is shagged so the hot water has to go back through the engine.. now about that webcam.. :tongue:
