Author Topic: Loose Scary Steering!  (Read 10162 times)
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
« on: 30 April 2012, 12:41 »
car : Golf mk4 GTi 1.8 20VT
The Problem: The car feels like the steering isnt attached! if i hold the steering wheel in the middle the car floats about the road. The car will always pull to the left but the steering wheel will sit to the right.
I've been under some investigation and im putting it down to bushes right now. I've noticed that the front wishbone rear bushes are quite worn, and theres movement in the wishbone if the steering wheel is jerked left to right.
Would this be causing my steering problem? Also got on order a new steering rack bush.
Any help appreciated!! :)
« Last Edit: 30 April 2012, 14:41 by Xtrhardcore »
Mk4 Gti - Gone but not forgotten!
Offline cullygti
Re: Need some brain power!
« Reply #1 on: 30 April 2012, 12:50 »
i have all new poly bushes through out and mine did it before and still does it now even with almost every part replaced  :smiley:
Offline Xtrhardcore
« Reply #2 on: 30 April 2012, 12:54 »
Well that doesnt sound to pleasing :P Its quite scary at like 70mph+
Could it be the rack then?
Offline madmanmart
« Reply #3 on: 30 April 2012, 12:56 »
Sounds like you need your tracking doing too.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline cullygti
« Reply #4 on: 30 April 2012, 12:58 »
tracking has just been done on mine when i purchased new tyres well i say done they said it was spot on so couldnt justify touching it as there was nothing to do  :grin: but it is much better than it was with the new tyres
there was summat on here before about the pulling to the left sure someone found what it was  :undecided:
Offline Xtrhardcore
« Reply #5 on: 30 April 2012, 13:03 »
Yeah been reading there here and UK-mkivs.net and cant seem to find a solid answer. :huh:
Going to change the bushes and get it tracked thursday and see if it makes any difference.
My tyre size is 255/45/17 would that be making much inconvenience?
« Last Edit: 30 April 2012, 13:09 by Xtrhardcore »
Offline xxChrisxx
Re: Loose Scary Steering!
« Reply #6 on: 30 April 2012, 16:52 »
It's a handling 'feature' of the car. It's extremely sensitive to camber, so will just tramline without warning.
The steering wheel should sit dead straight though, so it sounds as though it's been tracked up with the wheel not centred.
Offline Xtrhardcore
« Reply #7 on: 30 April 2012, 17:04 »
Right ok i'll get it tracked and replace the bushed that i've ordered anyway and see what happens,
But on the thought, would the movement in the wishbone cause any affect to steering?
Offline xxChrisxx
« Reply #8 on: 30 April 2012, 17:09 »
Any movement in any component (that isn't supposed to move) that connects the chassis and steering wheel to the road will cause some slack in the steering. The degree that it affects it is likely to be very small.
You could replace everything, the car will still do it, as they did it from new. The car just has sh!t handling.
If you take it to somewhere that is snooker table flat, you'll find it doesn't pull at all.
Offline Xtrhardcore
« Reply #9 on: 30 April 2012, 17:12 »
Oh Fair enough :) Thanks for the answer! been waiting to find a response for a while! Spot on  :wink:
