Author Topic: AUM limp mode  (Read 1447 times)
Offline Dan_GTi8v
AUM limp mode
« on: 29 April 2012, 20:52 »
Had a problem for a month or so tried a few things but still cant diagnose it
basically my car was running fine until I took a trip up and down the m4 to pick up some new alloys. It was quite a spirited drive and sometime on the way back the engine suddenly went into limp mode with a 'boost pressure limit exceeded' code :(
I have a code reader so I cleared it but every now and then it goes back into limp mode, I can clear it and it runs fine for a while but it always comes back and I know this isn't right. I have checked all my boost/vacuum pipes and they all seem fine, and have fitted a new n75. The new n75 I fitted was the ECS race valve which since fitting I have read some bad things about but as the car was going into limp mode before fitting this and it doesn't seem any worse than before I don't think its this
My car is a mk3 AUM conversion, SAI n112 n249 deleted and stage 1 mapped
anyone have any ideas what to check next? I don't know anything about the actuator so not sure what to check to see weather that's working or not, and I don't have a boost gauge yet
any help or advice appreciated cheers :)
Offline Big Tone
Re: AUM limp mode
« Reply #1 on: 29 April 2012, 21:26 »
There it's a thread lately on how to set uo waste gate actuator with 3 turn preload.
Other than that, f**k it off. My biatch does my fookin head in!
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline Dan_GTi8v
Re: AUM limp mode
« Reply #2 on: 29 April 2012, 23:26 »
f**k what off? :P the n75 or the engine? thats not an option lol its cost me far too much in time and money to think about getting rid  :grin:
Offline Dan_GTi8v
Re: AUM limp mode
« Reply #3 on: 29 April 2012, 23:36 »
I'm thinking it must be something that happened on the long drive, it was pretty late so I did boot it a bit and had the engine on boost for quite a while at a time. Could this of damaged the actuator or anything?
Offline Dan_GTi8v
Re: AUM limp mode
« Reply #4 on: 30 April 2012, 20:25 »
bump could I of damaged the actuator or just a coincidence?
Offline Scott D
Re: AUM limp mode
« Reply #5 on: 01 May 2012, 00:54 »
What code does it come up with?
Could be a duff MAP sensor or the wiring harness.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline AaronGS
Re: AUM limp mode
« Reply #6 on: 01 May 2012, 03:17 »
What Scott said - what exact code did you get and have you thought of trying a new MAP sensor if not sure of code.
I would try getting it logged properly on VCDS.
Offline Dan_GTi8v
Re: AUM limp mode
« Reply #7 on: 01 May 2012, 12:53 »
didn't actually think of map sensor
I think it was 17963 Boost Pressure Control: Upper Limit Exceeded, but would have to double check I'll have a look later if I hit limp when I'm out and about
whats the charge pressure control? n249?
