Author Topic: 8 valve turbo kit ??? anygood??  (Read 6605 times)
Offline DAVEMARX
« on: 29 April 2012, 20:51 »
I noticed on ebay a turbo kit from the states for the 2.0 8v vw engine.
im wondering will they fit the 1.8 mk2 engines if there any good, if anyone is using 1 or what is the alternative.
http://www.ebay.co.uk/itm/VW-85-86-87-88-89-90-91-92-GOLF-MK2-8V-2-0L-TURBO-KIT-/280588187867?pt=Motors_Car_Truck_Parts_Accessories&hash=item41545bf8db#ht_4733wt_1037
dave
Re: 8 valve turbo kit ??? anygood??
« Reply #1 on: 29 April 2012, 21:45 »
I believe they are designed to fit and be used with the crossflow cylinder head
Offline DAVEMARX
« Reply #2 on: 30 April 2012, 08:47 »
isnt  crossflow  ford  ???
says it fits straight on the 2.0 8v...
Dave
« Reply #3 on: 30 April 2012, 09:39 »
Nope, later 2.0 and the usa market had a crossflow head with the inlet manifold on the front.
Offline DAVEMARX
« Reply #4 on: 30 April 2012, 10:06 »
oh right i got ya.. hmmm interesting
are there any alternatives for uk spec mk2's apart from the usual 20v t converstion?? using the original engine 8v or 16v
what about a super charger kit similar to the g60?
Dave
Offline Khare
  • The bear that khares
« Reply #5 on: 30 April 2012, 12:33 »
Is there much point in doing it? I know the 20vT conversion is common but at the end of the day it's the most efficient. You can pick up a 20vT engine with all the bits for not that much these days and it'll end up being more durable, faster and more fuel efficient. The 1.8 GTI engine from a mk2 is not designed to be used with a turbo. I doubt the rods would hold the power very well...
« Last Edit: 30 April 2012, 15:32 by Khare »
« Reply #6 on: 30 April 2012, 13:52 »
As Khare said a 1.8t conversion is the better option.
Offline molegti
« Reply #7 on: 02 May 2012, 13:42 »
No but i believe the Ford "Kent" engine sometimes gets referred to as the crossflow but really its any engine with the inlet and outlet on opposite sides of the cylinder head.
Offline apie2004
« Reply #8 on: 03 May 2012, 16:06 »
And PB's are counterflow
