Author Topic: Need Urgent Help !!!!  (Read 1798 times)
Offline Adz Gti
  • Instagram - gti_adz
« on: 28 April 2012, 23:18 »
My mate Ian007miles check my car recently with his vagscanner due to the engine management light coming up, it came up with 17704 fault code, I got my coolent tempreture sensor changed (from vw Bosch part) and its still showing the code ? What could it be ? Someone......
Just Daily Dubbin
Offline topher
  • Administrator
  • fully functioning
Re: Need Urgent Help !!!!
« Reply #1 on: 28 April 2012, 23:25 »
thermostat most likely, unless you've been really unlucky and bought a knackered coolant sensor. where does the needle sit on the temp gauge in the dash while you're driving?
Offline Adz Gti
« Reply #2 on: 29 April 2012, 01:55 »
It sits at 90 but takes a long time to get there, and the coolent sensor was brand new only purchased it yesterday so it must be the thermostat, any idea of how much it will cost ? Cheers btw
Just Daily Dubbin
Offline dan2252
« Reply #3 on: 29 April 2012, 02:04 »
wiring could be faulty.. a mate of mine his car was showing coolant temp faults. put a new sensor in still there.. checked wiring and found a break in the wire
MK4 golf 1.8 turbo agu :)
Offline tonysgti
« Reply #4 on: 29 April 2012, 09:00 »
the code was cleared before re scanning i take it?
Offline Gavo1989
« Reply #5 on: 29 April 2012, 09:38 »
+1 id say check thermostat buddy, ive been through this and turned out to be the stat.
Offline Mr_Orange
« Reply #6 on: 29 April 2012, 10:12 »
+1 Real slow to warm up is classic thermostat buddy  :wink:
If you are replacing go with the Neuspeed 82deg part:
http://www.awesome-gti.co.uk/product.php?xProd=5590
Build thread clicky
Offline simon_709
« Reply #7 on: 29 April 2012, 10:27 »
The other day mine came up with a fault saying coolant temp sensor, and when I drive along the temp gauge sits right at the bottom of cold... Would this be the thermostat?
My Golf GTi, RS4 reps 17", coilovers, tinted windows, De-cat and middle box removed with 3" oval back box, stage 1 Revo re map, G60 flywheel/VR6 clutch, HID kit, Forge 007p,
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 29 April 2012, 13:42 »
i'd say thats the coolant temp sensor. you'd normally get some signs of heat with a broken stat
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 29 April 2012, 13:51 »
^this. if you dont erase codes after replacing suspect parts it will remain in the dtc memory as an intermittent fault in most cases. (although generally with the error in mapped cooling system code the fault lies with the stat unless you have other tell tale signs)
