Author Topic: 1.8t planning to Decat - remap or no remap????  (Read 2932 times)
Offline bigmarky
Re: 1.8t planning to Decat - remap or no remap????
« Reply #10 on: 28 April 2012, 23:25 »
if i remember right you'll only get some sort of circuit/signal failure show up as a fault code. the home-made way to test if the mechanical parts are doing their job is the suck-blow test :grin: i can never remember which one of the ports is supposed to be air tight.
Haha so I'm going to be spending my Sunday morning sucking and blowing the N75 ports lol ??? God help me!!!
Tornado Red, 99 AGU, full milltek, K & N, forge007p, 18\" A8 in custom Matt Black with Anthracite inserts, Custom remap, 22psi boost, HID\'s, full led\'s, bodykit.
Offline topher
  • Administrator
  • fully functioning
« Reply #11 on: 28 April 2012, 23:27 »
while you're down there give the engine a reach-around... to check the actuator rod has free movement :grin:
Offline bigmarky
« Reply #12 on: 28 April 2012, 23:31 »
Ha its already had a couple cheeky reach arounds and alls in working order  :wink: will get the N75 off and see if I can get any joy with that cheaper than a decat if it is!! Cheers mate
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #13 on: 01 May 2012, 18:48 »
36psi???? :laugh:
Even on actuator pressure your only going to get 28psi max,  the only way I can get 35psi+ from a K03 is to hold the wastegate shut solid with a bar...this gives around 340+lbft with major engine det :grin:
You could have a sticky waste gate??
 01455 617233
