Author Topic: Crank sensor  (Read 1426 times)
Offline mikey_magic
Crank sensor
« on: 28 April 2012, 18:08 »
Hi guys been having major troubles with my 8v over the last few days, does anyone know the crank sensor is on a 8v
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
Re: Crank sensor
« Reply #1 on: 28 April 2012, 18:34 »
Offline mikey_magic
Re: Crank sensor
« Reply #2 on: 29 April 2012, 12:23 »
Hi Rob thanks for this however have changed all the sensor cleaned throttle body but just find out there isn't fuel getting into the block checked injectors and all ok where do I go from here???
Offline Screech16v
  • MK3 20vt AGU
Re: Crank sensor
« Reply #3 on: 29 April 2012, 12:31 »
Is your fuel pump priming ? try changing relay 167
Offline dixie180
Re: Crank sensor
« Reply #4 on: 29 April 2012, 12:34 »
+1 on Screech's suggestion.
Rob
Offline mikey_magic
Re: Crank sensor
« Reply #5 on: 29 April 2012, 12:38 »
Hi rob done that already the car is now turning off but no Fuel in block as the plugs are bone dry and smell of fuel what so ever
Offline javalin
Re: Crank sensor
« Reply #6 on: 30 April 2012, 09:06 »
if there is no spark - then sounds like cam/crank sensor faulty.  The crank sensor is on the front of the engine, under the oil filter.  Usually find these have burn't away wiring, etc.  Cam sensor is in the dizzy, and usually find cracked wires in the lead & plug.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
