Author Topic: Airbag Light  (Read 2938 times)
Offline philmar
Re: Airbag Light
« Reply #10 on: 29 April 2012, 16:35 »
 Had the same thing on my Vento when I first bought it. Bought a scanner from  e-bay and reset it. The fault had been caused by removal of the steering wheel to replace the horn contact ring. Maybe you can sort yours by removing the battery lead for a while ?
Offline itavaltalainen
Re: Airbag Light
« Reply #11 on: 29 April 2012, 22:05 »
just a word of warning, that i probably bore people with by now but i will repeat it all the same :grin:
you run the risk of damaging the airbag controller if you attempt to communicate with it using ebay cables.
That's nothing to do with the ebay cable as such but a problem with the software (i.e. VAGCOM/VCDS):
http://www.ross-tech.com/vag-com/vw_issues.html
I am not aware of issues with that on mk3 Golfs at all.
Offline topher
  • Administrator
  • fully functioning
Re: Airbag Light
« Reply #12 on: 29 April 2012, 23:23 »
different issue. i can fix the 6Q0 firmware bug by obd (although its sometimes simpler to find a used ecu) but good luck pulling anything useful from the 6N0 type with a fried eeprom
Offline GTIANNIVERSARY16V
Re: Airbag Light
« Reply #13 on: 29 April 2012, 23:36 »
Well my cars gunna be mot'd at midland VW lol ...... So maybe you can pretend not to see the airbag light xD
Re: Airbag Light
« Reply #14 on: 29 April 2012, 23:38 »
Is that just the cables or handheld scanners as well.
Offline topher
  • Administrator
  • fully functioning
Re: Airbag Light
« Reply #15 on: 30 April 2012, 00:42 »
i dont do the mots :tongue:
dunno yet i haven't played with those to the same extent apart from the maxiscan stuff (which seems okay) too many variations to go through where as most of the hooky cables are based around the same bodged up design.
« Last Edit: 30 April 2012, 00:54 by topher »
Re: Airbag Light
« Reply #16 on: 30 April 2012, 23:45 »
Thanks for the info :afro:
Offline Dogbot
Re: Airbag Light
« Reply #17 on: 01 May 2012, 08:54 »
I have a maxiscan machine, its been fabulous not once had any issues.....
