Author Topic: Can i leave it like this?  (Read 6408 times)
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Can i leave it like this?
« Reply #20 on: 28 April 2012, 19:19 »
I'm a big fan of the 'rake' look but with those wheels the rear needs to sit more or less level with the front to make it look good. Some wider wheels and some coilovers will make this car.
Gavv8
« Reply #21 on: 28 April 2012, 19:32 »
I'd like to keep the standard wheels as i like the way they look but i am going to get the back lowered (springs ordered) , only issue i have is that i've got a scorpion backbox on it and the clamps are right above the rear beam which means it does knock if i've got people in the back seat although its fine without, could i use a different type of clamp that would be more flush than the usual u-clamps?
Offline Khare
  • The bear that khares
« Reply #22 on: 28 April 2012, 19:37 »
Or turn the clamp 180 degrees?
Gavv8
« Reply #23 on: 28 April 2012, 19:40 »
I have tried that but they still knock a little when the back is loaded up, i think i'm just going to have to get the ride height down then have a look at the exhaust and see what gives.
Gavv8
« Reply #24 on: 28 April 2012, 20:50 »
« Last Edit: 28 April 2012, 21:46 by Gavv8 »
« Reply #25 on: 29 April 2012, 00:07 »
That looks plain daft :grin:
Gavv8
« Reply #26 on: 29 April 2012, 00:36 »
-35mm springs ordered up..
Offline mrsaunders
« Reply #27 on: 29 April 2012, 02:57 »
mines like this at the mo, but only cause i aint got round to drilling my locking wheel nut off the c**t
Gavv8
« Reply #28 on: 04 May 2012, 21:09 »
-35mm mk2 springs now fitted at the back, i think it looks pretty good.
Offline stainesy
« Reply #29 on: 04 May 2012, 21:22 »
look good. but could go down and inch or so more  :wink: :grin:
