Author Topic: help with my clifford alarm  (Read 5333 times)
Offline stainesy
« on: 27 April 2012, 17:00 »
not sure if iv put this in right section.
i have a clifford alarm fitted to the car i have just bought.
seems to have a proximity sensor as everything makes it go of.
also inside the car next to the flashing red light there is a switch whats it for?
« Last Edit: 27 April 2012, 17:11 by stainesy »
Offline Ant1981
  • Feed me, prod me
Re: help with my cliffard alarm
« Reply #1 on: 27 April 2012, 17:04 »
Cliffard?
Well, I had a Clifford once. Had to get it adjusted as it was always going off, never had another one since.
'09 Kawasaki Ninja ZX-6R
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #2 on: 27 April 2012, 17:11 »
Probably to turn the flashing red light off.
Offline Ant1981
  • Feed me, prod me
« Reply #3 on: 27 April 2012, 17:36 »
It's more likely the switch that you press at intervals to enter a code in. My MK2 had one with to buttons on it.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: help with my clifford alarm
« Reply #4 on: 27 April 2012, 18:59 »
An alarm is only as good as the person who fits it :wink:
Cliffords are the best, proximity sensor can but adjusted by the user quite easily.
which clifford is it, ? CONCEPT ???  guessing its a G4
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Mr GTD
« Reply #5 on: 27 April 2012, 19:40 »
Hi
I had a Clifford in my previous car...
1st The proximity sensor - this keeps going off because the person(s) who fitted have set the sensor to very sensitive....when you bought your alarm you shud have also been given a certificate and a owners manual which shud explain how to correct the sensitivatey...if you cant correct it thro this for some reason go back to where you bought it from and ask them to sort it..
When I first had mine fitted it was very sensitive and the wind wud constantly set it off....I think there are 3 or 4 different settings for this...
2nd The red light - this is a anti theft thingy that shud help detour thiefs from attempting to steal your car, it shud only blink when car is stationary and keys are out of the ignition...if its still blinking when your on the move then there is something wrong and again you shud take this up with the fitter...
For the life of me I can't remember what the switch was for...I can't say I ever used either...
Read this it might be useful.....http://www.pistonheads.com/gassing/topic.asp?t=946578
« Last Edit: 27 April 2012, 19:43 by Mr GTD »
Offline stainesy
« Reply #6 on: 27 April 2012, 20:46 »
yes i have a certificate. says its a concept 50x
no instruction manual tho  :cry:
yes if i leave the car for about 30 seconds the alarm comes on.
if i go near it it buzzes at me to warn me off.
the switch next to the light has normal switch function click right side and click left. but on the left side you can also hold it down and release type if that makes sence. have not held it down tho as i dont want to change anything.
the key fob has the one main big button then 3 small buttons underneath but i havent tried them yet
Offline stainesy
« Reply #7 on: 27 April 2012, 20:55 »
sweet found this but still dont no what the switch does as i dont understand most of it lol. its frying my brain more than its already fried  :laugh:
sh!t i dont no the 4 digit code and its not in the certificate  :cry:
http://www.directeddealers.com/manuals/og/clifford/concept50xuk_owners.pdf
« Last Edit: 27 April 2012, 20:59 by stainesy »
Offline stainesy
« Reply #8 on: 30 April 2012, 22:22 »
do anybody no if i disconect the battery for any reason will i have to put a code in my alarm or will it work strait off the fob again as normal?
Offline stainesy
« Reply #9 on: 01 May 2012, 13:32 »
ah ha sorted it. my valet alarm code is the 4 digits in the middle of the searial number on the certificate.
can now access valet mode at last. woooohoooo  :grin:
