Author Topic: Calipers  (Read 1127 times)
Offline gashead1974
Calipers
« on: 27 April 2012, 08:36 »
Fitting a second hand set of calipers on my mk 3 this weekend.
I havent got the wind in tool but at work have found a grinder wheel spanner thans fits a treat. My question is will the caliper piston simply wind back in without any downward pressure on it or does it need pressure and turn at the same time.
The piston is turning freely by using the grinder spanner but doent seem to be retracting???
Offline Dogbot
Re: Calipers
« Reply #1 on: 27 April 2012, 09:47 »
it does need downward pressure but not more than you can apply with the grinder spanner..... thats my lil trick too... i have a wind back tool.... i'd be damned if i knew who i lent it too tho....
Offline gashead1974
Re: Calipers
« Reply #2 on: 27 April 2012, 09:49 »
Happy days, I'll keep winding then :smiley:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Calipers
« Reply #3 on: 27 April 2012, 14:47 »
If they are nice and loose it shouldnt be a problem,  i use a big screwdriver, when i cant be botherd to get the winder out the box.  :grin:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
