Author Topic: VR6 wineing nosie?????  (Read 2590 times)
Offline jayeshjethwa
« on: 26 April 2012, 22:14 »
Theres a wineing noise thats coming from the rear of the car some people have sed its the fuel pump! is that true?????
Offline tweed
Re: VR6 wineing nosie?????
« Reply #1 on: 26 April 2012, 22:19 »
Could be that or the central lcoking pump.
Has it got fuel in it?
When does it do it?
« Reply #2 on: 26 April 2012, 22:24 »
The car has fuel, as soon as you turn the car on it the nosie starts.
« Reply #3 on: 27 April 2012, 11:26 »
Ping
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 27 April 2012, 17:25 »
Fuel pump should run for a few secconds with the ignition, then stop and start again as the engine is cranked,   lift the boot carpet up, put the rear seats down and see if its louder, if its louder then its going to be the fuel pump.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
« Reply #5 on: 27 April 2012, 17:46 »
If it is the fuel pump, how much can i pick up one for?
Offline leigh_harty
  • Audi AGU
« Reply #6 on: 27 April 2012, 18:16 »
£60-ish from euro.
Thats the full pump if i remember because you can buy separate parts
Dont lose your dinosaur!
Offline Rmachines
« Reply #7 on: 28 April 2012, 09:39 »
How noisy is it? because its normal for it to whine, is the cover plate on and the boot floor down?  as that acts as soundproofing for it,  also might be worth popping it out and checking the gauze isnt clogged up,  My old 8v used to have a noisey pump but it never caused any issues.
« Reply #8 on: 02 May 2012, 09:00 »
ive just been driving the car & the car cuts out at stand still.. does it a few time here n there,i put my foot down & it kinda wants to decrease in power & cutt off.... still wines like a monster.... the rear carpet & seats have been out for a long time ...the feul pressure regulator has been changed from 3bar to 4 bar to ease the pressure but still the wining noise is there.
« Last Edit: 02 May 2012, 10:09 by jayeshjethwa »
« Reply #9 on: 14 May 2012, 13:19 »
On the weekend i went to get the car checked over. The guy said the car is over fueling he check the plugs and they were coved with petrol. the car is also blowing out alot of black smoke.
the car has a 4 bar fuel reg, it was advised to change it to 3 bar.
