Author Topic: Cracked head  (Read 3167 times)
Offline DubAndDubber
Cracked head
« on: 26 April 2012, 21:01 »
As above, what are the symptoms?
Mates got a 115pd and i think the heads cracked! Oh dear..
Mk5 Golf Gti 06'
Offline EsSeX dAn
Re: Cracked head
« Reply #1 on: 27 April 2012, 21:07 »
itll be like having a blown head gasket. pends where its cracked really. oil in water or vice versa, mayo under the oil cap, over pressurised coolant system, rock hard cooland pipes, blowing coolant out the overflow, heater going cold when you get your toe down, making air locjs in the system
whats happening with urs?
i think i love you.....
Re: Cracked head
« Reply #2 on: 27 April 2012, 21:50 »
he had a pressure text and it came back fine.
he gets air locks and like you said, when he gives it the boot the heaters blow cold. I reckon it could either be water pump or cracked head.
Mk5 Golf Gti 06'
Offline EsSeX dAn
Re: Cracked head
« Reply #3 on: 29 April 2012, 18:22 »
do u mean a compression test? do the coolant pipes go very hard after a longish run? also does a bit of coolant over a few days? mine does this, also the temp gauge rises when i floor it but comes bk to normal after a minute or so.i really do think its the head gasket thats gone between compression and a water jacket which would overpressurise the system and spit it out the overflow. also look around behind the headlight for wet patches
Offline rookwood232
Re: Cracked head
« Reply #4 on: 01 May 2012, 19:23 »
had similar prob on 150PD for sometime mate, coolant loss pint/100 miles, all hoses replaced, stat, header. Water clean, oil clean too, 25K engine so i may have big probs too, also running rough. No sign of coolant seepage anywhere unfortunately, heater works fine
Tuesday she is having the Allard egr delete kit fitted and more examination on hard to reach coolant pipes. Will let u know outcome. if no good its head off.
Any recommendations on replacement engines/heads folks? Mine is engines direct, ran well for 20K or so till daughter ragged it on the A30. Might try a specialist builder this time.
Golf GTI Mk4 150PD 52 Reg 3d silver, black interior blue piping, rough runner, monster hisser when she goes
Offline EsSeX dAn
Re: Cracked head
« Reply #5 on: 02 May 2012, 23:28 »
it could be the chocolate camshaft strikes again rockwood
Offline Dean_W
Re: Cracked head
« Reply #6 on: 16 May 2012, 01:56 »
Just had the camshaft problem on mine........ :cry:
2002 GT TDI, Hybrid, Diff etc. 221BHP 355LB/FT
