Author Topic: How do you make these?  (Read 2487 times)
Offline Kent
« on: 26 April 2012, 19:26 »
Is this a hard conversion to undertake on your own if so does anyone know how to do this? or will it be better of buying the kit of this guy?
http://www.ebay.co.uk/itm/320449647118?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648#ht_2292wt_1289
Offline X4MGS
  • VAG Parts SNOB!!!
For More Info Click To See;
VW BUSH
Re: How do you make these?
« Reply #2 on: 26 April 2012, 20:54 »
Diagram
http://www.matey-matey.com/tech_diag.shtml
Parts list
http://www.matey-matey.com/uprated_headlight_wiring.shtml
If you don't work somewhere that you can liberate the bits from or you are rubbish with your hands,  then you might as well spend £40 on the kit X4MGS posted the link to
Offline basssound
« Reply #3 on: 26 April 2012, 21:11 »
That matey matey wiring loom is only an uprated loom for the dip beam...
There are details about a 3 relay wiring loom that uprates the dip beam, main beam and spots/fog lamps.
Really all you would need to do is to wire up 3 relays using the diagram matey matey has supplied but wire up three relays so that the dip and main bean cut each out when you move the stalk and as for the spot/fog lights, in essence its the same loom as above but use the fog lamp signal from the stalk to switch the relay on.
VW BUSH
« Reply #4 on: 26 April 2012, 21:29 »
Quite correct use an extra relay to switch loom to battery fed supply, use diagram as a guide just replicate as required
Can even be done to rear lights :smiley:
Offline Kent
« Reply #5 on: 27 April 2012, 09:53 »
I will by one I thinks as that is a little tricky for my sausage fingers to undertake.
Offline cняis
« Reply #6 on: 28 April 2012, 00:43 »
Yup. I work for a motors factors and can buy bits at cost, however with all the relays/wiring/connectors etc I couldnt save much on the ebay price of £30 to £40 for a pre-assembled item.
I only chose to make mine because:
a. The experience
b. I could make the loom to the desired length
Offline Kent
« Reply #7 on: 30 April 2012, 10:43 »
ive purchased one. will keep you posted on what they are like
