Author Topic: 150PD - 783 Race injectors + standard turbo + remap  (Read 6495 times)
Offline Defender
I know the standard turbo is kinda limited in the amount of power it will give out (Can't remember the exact figure) but just wondering if anyone can give a rough guess as to what the standard turbo, race injectors and a remap will give out...............or are the injectors completely pointless with the standard turbo?
Offline sprout99
Re: 150PD - 783 Race injectors + standard turbo + remap
« Reply #1 on: 25 April 2012, 20:36 »
the weak point is the clutch............the car can deliver great torque but cannot put it on the road
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline Defender
« Reply #2 on: 25 April 2012, 20:44 »
Sorry should have said it's got a single mass conversion already so the clutch should be fine, I'm just wondering what sort of torque / power the above will give?
Offline Steve_PD
« Reply #3 on: 25 April 2012, 20:47 »
Well standard turbo maxes out around 190-195bhp
But with a upgraded turbo the injectors max out at 220-230bhp
So going by that it would be pointless to fit better injectors without a better turbo
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #4 on: 25 April 2012, 20:59 »
People who fit larger turbos see 225 with a hybrid 17/22 without injectors. If you fit the GTB20(I think its 20 or is it 40? :undecided: )and injectors then people have see 260ish...
Offline Steve_PD
« Reply #5 on: 25 April 2012, 21:01 »
The Q7 turbo can make 300bhp
Offline Defender
« Reply #6 on: 25 April 2012, 21:06 »
Thanks, that's exactly the detail of technical info I was looking for...............but rubbish on the other hand that now I gotta save for a turbo  :cry:
Offline scarr89
« Reply #7 on: 25 April 2012, 21:23 »
If you could afford to buy race injectors, about £800 am I wrong? then surely you could afford to buy a turbo instead!? Hybrid turbo can be had for £600!
Offline Defender
« Reply #8 on: 25 April 2012, 21:30 »
They can be had cheaper if you have your injectors rebuilt with the nozzles, but yes if you buy them outright £800 is about right.
What hybrid can you get for £600?
Offline scarr89
« Reply #9 on: 25 April 2012, 21:48 »
How much would that cost for a rebuild then? What would the injectors you mentioned top out, any idea?
http://www.ebay.co.uk/itm/130666936161?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1014wt_1270
I know it has finished but the guy sells more I assume. CR turbos could make you one up as well I think.
