Author Topic: Cruise control in a 54 plate GTI  (Read 2005 times)
Offline Rhyso
« on: 25 April 2012, 20:25 »
Got a mate with a 54 plate GTI who wants cruise control fitted. Is it just a case of replacing the stalk or is a new steering module required?
Ta  :smiley:
Offline Smugboy
Re: Cruise control in a 54 plate GTI
« Reply #1 on: 25 April 2012, 21:29 »
New stalk + Vagcom to enable i believe
Dealer quoted me £210ish
I'm having these guys come around and do it for £165 (£150 + 60p a mile I think), so depends where you are
http://poollretrofits.com/contact
I know others offer this service to.
Mine is a 57 plate, but I don't think it's different on earlier examples
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 25 April 2012, 21:42 »
if i remember right the GTIs all had MFA so the steering module should be ok. You can check the part number with vagcom though. Pre 2006 i believe you need to add the extra wire which is a bit of a pain.
Offline Rhyso
« Reply #3 on: 25 April 2012, 22:39 »
Ill be fitting it myself; i did the cruise install on my Audi  :smiley:
@ toph is tge wire to the ecu or is it all under the steering column?
Offline Rhyso
« Reply #4 on: 25 April 2012, 22:50 »
Just found a guide about the wire.....doh  :angry:
