Author Topic: Diverter valve replacement  (Read 1640 times)
Offline gman86
« on: 25 April 2012, 20:02 »
Hi guys,
There seems to be an awful lot of confusion / inaccurate information on the DV's used on the MK6 with the 2.0 TSI. I suspect mine is starting to go as I'm losing about 4psi of boost top end versus the commanded boost pressure shown in VCDS.
Has anyone had to have their valve replaced? If so, do we have the later 06H "diaphram-less" valves, or is there an overlap with the older 06F? Mine is a July 2010 model.
Offline Snoopy
  • Moderator
  • Geoff.
Re: Diverter valve replacement
« Reply #1 on: 25 April 2012, 23:11 »
Not had time to go and see the dealer about mine as I think mines on the way out too.  :undecided:
 http://www.golfgtiforum.co.uk/index.php?topic=226603.0
The part number on mine is listed in that above thread mines an early 2010 car.
How do you monitor it with vcds as I may see what mine is doing?
Thanks.
« Last Edit: 25 April 2012, 23:13 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline gman86
« Reply #2 on: 26 April 2012, 12:38 »
In the measuring blocks, choose RPM, Boost specified and Boost actual. I'm a good 4psi down at the top end from what's specified so I think it's on the way
Offline ajmoir36
« Reply #3 on: 27 April 2012, 15:35 »
Must do this on the GTD too, doesnt feel as sharp as it should.  Although the service indicator says 800 miles left.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
