Author Topic: Can anyone think of a waterproof grease/oil?  (Read 2639 times)
Offline Khare
  • The bear that khares
« on: 25 April 2012, 19:36 »
My car hates the rain, whenever I go over fairly big standing water it'll start spluttering from water going into the distributor and coil. Can anyone think of a solution? I've thought about possibly putting a very fine bead of silicone or instant gasket where the distributor cap meets the distributor, to stop water going into the cap. For the coil though I have thought of using vaseline to seal it, but I can see this coming off fairly soon. Can anyone think of an oil/grease that would seal the coil?
WD40 comes off far too easy and it's not a long term solution.
Offline danny_p
Re: Can anyone think of a waterproof grease/oil?
« Reply #1 on: 25 April 2012, 20:19 »
bog standard grease is plenty waterproof.
the classic soultion is a rubber glove over the dizzy.    better to swap out the duff bits tho really
all the VW's have gone bar 1.
Offline Khare
« Reply #2 on: 25 April 2012, 22:19 »
Coil was bought brand new just over a year ago, cap and rotor is about 14 months old, could do with a renew really.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #3 on: 28 April 2012, 11:14 »
I would use a silicone spray,  just make sure its super dry before you do else it will seal the water in  :grin:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Khare
« Reply #4 on: 28 April 2012, 12:23 »
Yeah definitely  :grin: Silicone spray sounds good though, will try it out  :smiley: :smiley:
Offline Khare
« Reply #5 on: 28 April 2012, 13:04 »
Just read up that dielectric grease on the rubber boots of the leads works well too.
I think I'm going to go for that + sealing the distributor with a fine gasket of silicone and then use this to spray over the complete ignition system specifically the coil.
Offline Rmachines
« Reply #6 on: 28 April 2012, 22:53 »
Yea that damp start is a plastic based spray very much like silicone spray, works very well, have used it in the past, Reapply every 6 months or so, but a can will lasts a few years, so its a cheap fix if it does the job.  :wink:
Offline Khare
« Reply #7 on: 29 April 2012, 16:53 »
Have bought and sprayed around. We will see how it goes. This will work well on my kart in wet races too, as everything is exposed.
« Reply #8 on: 29 April 2012, 20:23 »
You can get waterproof grease (honest) we use it in work for machines working in the sea or water.
