Author Topic: Gearbox clonk  (Read 959 times)
Offline km
Gearbox clonk
« on: 25 April 2012, 16:12 »
Recently, car's been clonking when I accelerate and also when my foot comes off the throttle.
Thought this would have been an engine mount but there doesn't appear to be much movement when I rev it.
And I've had new dogbone bushes and bolts a few months ago.
I've also noticed that when the car's rolling and I dip the clutch in, and move my gear stick from 2nd to 3rd and vice versa, the same clonking exists.
What could this be? I have adjusted my cables recently, it goes into gears fine.
Offline richw911
Re: Gearbox clonk
« Reply #1 on: 25 April 2012, 16:44 »
Broken / worn bushes in the dogbone mount (Gearbox mount)  :undecided:
Offline km
Re: Gearbox clonk
« Reply #2 on: 25 April 2012, 17:03 »
I'll check everything I can..
..when it stops raining :angry:
Offline DubAndDubber
Re: Gearbox clonk
« Reply #3 on: 25 April 2012, 19:25 »
my friend has this. to me it looks and sounds like the gearbox tower housing. manually change gear by the tower, give it a bit of force, it should sound similar to the noise when driving.
dont ask me what the solution is though i couldnt figure it out!
Mk5 Golf Gti 06'
Offline km
Re: Gearbox clonk
« Reply #4 on: 12 May 2012, 16:48 »
checked dogbone mount, its all tight.
changed passenger engine mount with a standard one yesterday..
clonk disappeared when doing higher speeds but not low speeds, eg 40+ mph.
took my wheel off to check things out today, put it back on, now the clonk has pretty much disappeared. :huh:
