Author Topic: mk3 golf gti 2.0l 16v  (Read 2112 times)
Offline 16vheader
« on: 24 April 2012, 21:46 »
hi there im not sure if i have done this right but i have a problem with my golf after running it for 30 mins the car cut out i was just wondering if anyone has any ideas at what it could be thanks paul
Offline 16vheader
Re: mk3 golf gti 2.0l 16v
« Reply #1 on: 19 May 2012, 22:43 »
hi people i have had this problem sorted now it was the crank shaft sensor i now have another problem i cant seem to select any gears on my hydrolic clutch does anybody know if it is down to the oil or the clutch oil thank you paul
Offline Bandit127
« Reply #2 on: 20 May 2012, 08:12 »
Hi Paul.
Sorry, I don't have an answer for you.
You are posting in the For Sale section. I have asked a moderator to move this thread to the Golf Mk3 section where you stand a better chance of getting your question answered.
Good luck.
Offline xAntiVenxm
« Reply #3 on: 20 May 2012, 12:25 »
crank shaft sensor went on mine as well, annoying things! for being unable to select any gears, check the mk3 maintenance & info link on the mk3 section, has tons of guides and questions answer, can just search. check if you've got the appropriate amount of gear oil, or it could possibly be that your gear selecting mechanism is out of alignment, there should be a line coming out of the gearbox, sometimes covered with a rubber boot, which is the gear selector. if it's pushed too close to the gearbox, or pulled too far out, and then tightened up you won't be able to reach gears. but definately check that maintenance section on this forum!
Offline xAntiVenxm
« Reply #4 on: 20 May 2012, 15:35 »
wrong topic, dunno how to delete posts :S
