Author Topic: Goodridge hose kits  (Read 3581 times)
Offline gti gaz
Re: Goodridge hose kits
« Reply #10 on: 24 April 2012, 22:21 »
hum i like very much i have been thinking of r 32 frunts and mk 4 rears with uprated pipes  :tongue:
 Any one in cornwall lets sort more meets!!!!
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #11 on: 24 April 2012, 22:36 »
I fitted the S3 front set up to match my engine along with Ceramic pads
GTI discs Versus the S3
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Ess_Three
« Reply #12 on: 24 April 2012, 22:44 »
You will need at least 17" wheels then.
And then, only some 17" wheels clear the R32 front brakes...mostly 18s required.
..but gaining motorcycles.
Offline Ess_Three
« Reply #13 on: 24 April 2012, 22:45 »
Same here...they seem up to the job.
« Reply #14 on: 24 April 2012, 23:59 »
If R32 is the same as the Cupra R set up then 17"s tend to need spacers from the threads I have seen.
Offline F17BAD
« Reply #15 on: 25 April 2012, 08:54 »
no mate different slightly bigger
must be to help stop all the weight of the R32 (slow cars IMO)
the 312 upgrade is more than enough especially when you use a decent pad.. forget fancy looking discs too, OEM plain ones are the best
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #16 on: 25 April 2012, 10:18 »
I thought R32 were 323mm and the Cupra R were 312mm?
« Reply #17 on: 25 April 2012, 11:10 »
Standard Cupra (180bhp) is 312mm same as Octavia vRS, Cupra R has the Brembo set up with 323mm brakes
« Reply #18 on: 25 April 2012, 13:01 »
Ah of course, I remember seeing the red Brembo calipers on the 'R's now.
Offline F17BAD
« Reply #19 on: 25 April 2012, 13:28 »
R32 and TT 3.2 V6.. and Audi A3 3.2v6 use 334mm fronts
Cupra R is 323mm
Audi S3, TT 225 bhp, Golf 4mo, VRs Octy, Golf GTI AUQ 180 bhp and Leon Cupra 180 bhp is 312mm
312mm just fit behind 16". and very powerfull braking on the lighter mk3 shell.
You would need the 6mm spacers to make the calipers fit. we made mine as a 1 piece spacer.. as per pics in my build thread
