Author Topic: Handbrake help!  (Read 1250 times)
Offline Deefadog
  • Mk2 16V (November 89)
Handbrake help!
« on: 04 June 2005, 17:43 »
Need some help with the handbrake!
Inside the car the two cables attaching to the handbrake, the passenger side cable has lots of slack compared to the drivers side cable! Even when i turn the nut all the way down there is still slack!
Can this only be adjust from inside, or is there an adjustment on the brake itself?
Offline Mr Blue
Re: Handbrake help!
« Reply #1 on: 04 June 2005, 19:18 »
is the handbreak cable still attached to the caliper?
Use some bolts as spacers and tighten the end nut up maybe
Offline Deefadog
Re: Handbrake help!
« Reply #2 on: 04 June 2005, 22:35 »
Yep, the end is attached to the caliper!
The problem from what I can see is that it does not spring back fully on the caliper, If i push it up by hand, the slack is taken up and it's fine, pull the handbrake up and doen and it's seem to get stuck.  Not sure what this is or how to cure it??
Offline Mr Blue
Re: Handbrake help!
« Reply #3 on: 04 June 2005, 23:08 »
i had that problem with mine a few days ago. changed the handbreak cable as it was 'sticking' inside itself.
cheap and piss easy to change. dont even need a car jack. :smiley:
Offline Deefadog
Re: Handbrake help!
« Reply #4 on: 05 June 2005, 09:46 »
I'll pop down gsf tomorrow, may aswell change them both :) cheers
The arm that get pulled down by the cable seems to not spring back up as it should though, can this arm just be removed and greased up?
