Author Topic: Spacers+nuts  (Read 918 times)
jockgti
Spacers+nuts
« on: 24 April 2012, 11:31 »
what size nuts are best for 10mm spacers? would you go to 40mm or will 35 suffice? these are the ones i'm thinking of getting i've messaged the guy to see what size he supplies,as will need to get new lockers as well.is 40mm long enough for 15mm spacers as it would be 27+15 so 42mm
http://www.ebay.co.uk/itm/300678491650?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_3587wt_1270
http://www.ebay.co.uk/itm/300590980170?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_3353wt_1270
Offline cullygti
Re: Spacers+nuts
« Reply #1 on: 24 April 2012, 11:39 »
what is it you want to know mate im having a blond moment  :laugh:
have you already got the spacers and just need longer wheel bolts to go with them  :smiley:
Offline cullygti
Re: Spacers+nuts
« Reply #2 on: 24 April 2012, 11:47 »
got it i think 35 will be ok as its only 2mm and should be ok for rear to as again its only 2mm i use standard lenght on front with 5mm spacer and no probs just my opinion but others may say different and go for a little longer in lenght  :smiley:
jockgti
Re: Spacers+nuts
« Reply #3 on: 24 April 2012, 12:34 »
yeah i thought 35mm would be ok for front as i'm running 5's with standard bolts,but trying to find 10mm hubcentric without bolts is a pain,as i already have 35mm bolts,might just go 10mm front and back if i can find spacers without bolts then would only need some new lockers.
Offline Steve_PD
Re: Spacers+nuts
« Reply #4 on: 24 April 2012, 13:05 »
Bolts not nuts  :tongue:
35mm and 40mm will do
jockgti
Re: Spacers+nuts
« Reply #5 on: 24 April 2012, 13:11 »
order 40mm lockers and trim the fronts down? or you think the fronts will be ok?
Offline Steve_PD
Re: Spacers+nuts
« Reply #6 on: 24 April 2012, 17:48 »
Order 40mm and trim. you need some for the back and they only come in a set of 4 anyway
