Author Topic: dizzy seals  (Read 3023 times)
Offline devilscaff
  • allways up for alaugh
dizzy seals
« on: 23 April 2012, 19:22 »
Is there anyway of replacing the seal inside the dizzy if so how do you take it apart, iv already replaced the outer o ring but now have oil comming from inside the dizzy thanks
Offline clipperjay
Re: dizzy seals
« Reply #1 on: 23 April 2012, 19:33 »
Carefull I think there is about three seals two of them paper gaskets one rubber. Its been a while since Ive done one.
Offline raferackstraw
Re: dizzy seals
« Reply #2 on: 23 April 2012, 19:45 »
8v or 16v?
16v inner seal is a 12.5mm inner diameter you can get a 12mm inner diameter from any good bearing seal supplier which will fit, i did this with the spare dizzy i got off ebay
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline devilscaff
Re: dizzy seals
« Reply #3 on: 23 April 2012, 19:48 »
how'd you take it apart?
Offline clipperjay
Re: dizzy seals
« Reply #4 on: 23 April 2012, 20:08 »
Its not easy need punches and sometimes heat just to take out small bloody pins!
Forget the paper gasket that was on an ABF dizzy I think its one seal on the 16V. But depends if you are changing out washers and other parts like hall senders. IMO you can get a new one for £70 odd and with less hastle the fact you are asking us how to take it apart it might be too much grief for you?
VW BUSH
Re: dizzy seals
« Reply #5 on: 23 April 2012, 20:23 »
8v or 16v?
Make sure you at least get a viton seal :wink:
Offline devilscaff
Re: dizzy seals
« Reply #6 on: 23 April 2012, 20:32 »
Your right shouldn't bother have to look for a good replacement dizzy,was getting a bit above me station
Offline clipperjay
Re: dizzy seals
« Reply #7 on: 23 April 2012, 20:51 »
Ignore me and just do it, but you need a step by step or get any old broken one and take it apart to see how its put together taking pictures to record where washers and seals go on the shaft before disassembly  :smiley:
Offline devilscaff
Re: dizzy seals
« Reply #8 on: 23 April 2012, 22:10 »
I do have an old one and a vice might just experiment!!!!
