Author Topic: Cold Air Feed [Fitted with pics]  (Read 4772 times)
Offline Scott D
Re: Cold Air Feed
« Reply #10 on: 24 April 2012, 16:47 »
had barely any difference in peak g/s when did logging comparing a CAI with Apexi filter vs Jetex cone without an air feed.
only difference I felt was before the boost throttle response not as sharp and a small increase in lag with the cone, heat shield and 3" air feed with the cone seemed to be an improvement.
would like to do more logging but only so much can be done on my local test track...
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Cold Air Feed
« Reply #11 on: 24 April 2012, 18:54 »
Power on mine was exactly the same with and without an airbox/R32 intake
Offline sveed1.8T
Re: Cold Air Feed [Fitted with pics]
« Reply #12 on: 29 April 2012, 19:20 »
Was a bit of a fiddly job, as there is not that much space down the side of the battery (as I have a cover), oh, and the pipe was 3" in diameter! After removing the battery and all surrounding trim, scraping my fingers, repositioning the little air sensor and (I think) the horn and trimming the bumper grill, the job is done! :cool:
I am so glad, because I was having issues sleeping, but now I'm in for some peaceful nights! :grin: :tongue:
« Reply #13 on: 29 April 2012, 20:45 »
Cracking work, should make a big difference :smiley:
