Author Topic: 1.8t water temp gauge  (Read 3314 times)
Offline Dan_GTi8v
« on: 22 April 2012, 21:47 »
This may sound dumb but I've never been in a mk4 1.8t so don't know if they have a water temp gauge as standard, but I would like to fit one in my mk3 conversion which definitely doesn't have one. Is there a standard spot on the 1.8t that I can get a reading from or will I have to tap it from somewhere?
I know 42 draft do an adapter but thats 50 bucks + overseas postage, and I don't think I want one that badly  :grin:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: 1.8t water temp gauge
« Reply #1 on: 22 April 2012, 21:54 »
they have same gauges as mk3 (obviously different clocks)
does yours not work on the MK3 clocks ?
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Dan_GTi8v
« Reply #2 on: 22 April 2012, 21:59 »
isn't the one on the clocks the oil temp? sh!t im such a noob  :grin: my rad fan never comes on and as that gauge never goes over halfway I guessed it was oil temp
« Last Edit: 22 April 2012, 22:00 by Dan_GTi8v »
« Reply #3 on: 22 April 2012, 22:05 »
Oil temp is on the mfa display, gauge is water temp.
Offline Dan_GTi8v
« Reply #4 on: 22 April 2012, 22:17 »
so if there is one as standard what is this adapter for?
http://store.42draftdesigns.com/VW-mk4-18T-Water-Temp-Adaptor_p_60.html
is the mk3 gti rad bigger than the 1.8t rad? cant think of any other reason my fan wont come on, I know the wiring is good as its all been tested and I have a new ecs low temp thermostat and sensor
Offline EsSeX dAn
« Reply #5 on: 22 April 2012, 22:44 »
fan problem could be a problem with the fan switch on the radiator.
i think i love you.....
Offline Dan_GTi8v
« Reply #6 on: 22 April 2012, 22:52 »
its all good if I bridge the pins on the rad temp sensor the fan comes on, no worries just thought if 42 draft sell the adapter there must not be one standard of something. bit confused what its for now though  :huh:
Offline rio_gti
« Reply #7 on: 22 April 2012, 23:44 »
If the temp doesn't go above half way then there is no reason for the fan to come on   :undecided:
« Reply #8 on: 22 April 2012, 23:45 »
Agreed, mine work all ok but it is very rare they come on unless I am running the air con.
Offline Dan_GTi8v
« Reply #9 on: 22 April 2012, 23:55 »
This is why I thought there was a problem, when I had the mk3 engine in there it didn't go above halfway either but the fan would nearly always come on after getting home from a night shift (nice clear m25  :cool:) but now with the new 1.8t it never does
also added to my concerns when I fitted the lower temp stuff and it still never came on
If all is normal though then I guess its ok  :smiley:
still wondering what the point of that 42 draft designs adapter is though :P
