Author Topic: what banded steel width should i get  (Read 7439 times)
Offline stainesy
« on: 22 April 2012, 11:52 »
ok peeps im back i am picking up a mk3 golf gti this week in dragon green and i have found a bloke that will make me any size banded steel i like so what size shall i go for? what size is ok to use that isnt gona cause to much hassle? im going to roll the arches and use coilys.
im going for 16" wheels on this one as last time was way to low with the 15" rims
is 9j rear and 8j fronts a good option?
Offline murraymint
Re: what banded steel width should i get
« Reply #1 on: 22 April 2012, 12:03 »
Too low? Never!  :grin:
I think you might need some arch work if your gunna run that wide with 16" rims.
josh
Offline stainesy
« Reply #2 on: 22 April 2012, 15:00 »
would it be better to run that wide with 15" rims then?
i am going to take people advice and do what is best as i want it right. the bloke will supply and make the banded steels any size for £350 so what do you think is best for just rolled arches and inner arches removed?
Offline Junior74
« Reply #3 on: 22 April 2012, 15:11 »
if you want it right then do the arch work...
Offline stainesy
« Reply #4 on: 22 April 2012, 15:53 »
what do you mean by arch work? other than rolling and removing some of the inner wing?
im not getting them flaired
Offline tweed
« Reply #5 on: 22 April 2012, 16:19 »
If you tell me how wide the steels are and the et. I will be able to tell you the new et with 9" and 8"
Offline Junior74
« Reply #6 on: 22 April 2012, 16:24 »
Just read my last post, sorry, didn't mean to sound blunt...
The wheels I have are 16" 8.5 front and 9.5 rear and needed the arches flared but only slightly.
Offline stainesy
« Reply #7 on: 22 April 2012, 18:18 »
ah right so you think if i get say 8j front and 9j rear they will be ok with just rolled arches. on a 16" rim?
Offline shelaghmk3gti
« Reply #8 on: 22 April 2012, 18:24 »
staines accept my request on dub swap plz xx
Offline stainesy
« Reply #9 on: 22 April 2012, 18:33 »
dont mate. i forgot i even had that group on facebook lol
