Author Topic: Engine Mountings  (Read 5336 times)
Offline Ukpitbull
Engine Mountings
« on: 30 September 2003, 13:51 »
Im trying to figure out which engine mount is playing up on my GTI 8v. When you accelerate normally the engine rocks back, shaking the car. Is the front mount supposed to damp this action or is it the rear. There seems to be alot of movment from the front mount.
Offline Gambit
Re:Engine Mountings
« Reply #1 on: 30 September 2003, 14:30 »
the rear is meant to take the brunt of the strain, if the rear goes then the front (which aint v.strong) will show signs of movement
Offline Gambit
Re:Engine Mountings
« Reply #2 on: 30 September 2003, 14:34 »
i also have a brand spanking new rear mount & also a 6mth old front mount that will fit your car
there is nothing wrong with the front, it was meant to be faulty but turned out to be the rear mount
offers?!?!
golfvr6
Re:Engine Mountings
« Reply #3 on: 30 September 2003, 17:10 »
The FRONT engine mount takes most the strain, thats why its usually the one that fails.
golfvr6
Re:Engine Mountings
« Reply #4 on: 30 September 2003, 17:12 »
Get someone to rock the engine while you look for play in all the mounts. When they go , you will know about it!
Offline moonraker
Re:Engine Mountings
« Reply #5 on: 30 September 2003, 23:04 »
HI - If you are still not sure, then snap nor was I, so I jacked up the engine via the gear box and slipped out the mounting which only took about half an hour and checked it out - yep it was buggered (am I allowed to say that) okay so I had to slip it back in til I get another but at least theres no more trying to figure out. It is more than likely that you would be able to tell if the mount is shot just by jacking the engine up and looking at the mount as you do so
cheers
Steve
Offline moonraker
Re:Engine Mountings
« Reply #6 on: 30 September 2003, 23:06 »
just checking out what teletype does
Offline Gambit
Re:Engine Mountings
« Reply #7 on: 01 October 2003, 08:47 »
the fronts are notoriously weak and they do go first, but its the rear that takes the brunt of the strain, when this goes then the front will fail within a matter of weeks!
golfvr6
Re:Engine Mountings
« Reply #8 on: 01 October 2003, 10:21 »
Front is weak? i don't think it is , look at the size of them, the front just takes most of the strain.
Offline Gambit
Re:Engine Mountings
« Reply #9 on: 01 October 2003, 13:50 »
fronts are nowhere near as strong as the rear's
