Author Topic: Forge actuator awful fitment  (Read 1356 times)
Offline shaft69
« on: 20 April 2012, 19:42 »
Fitted my forge actuator to fitment's awful, top bolt fitted in middle hole on actuator nowhere near hole on turbo and bottom hole bracket sits about 5mm too high. Had to drill new hole in bracket and space bottom hole with washers. On performace before peaked at 19psi and held at 15, now peaks 21 and holds at 18psi and can feel difference. easy job hardest thing messing with bloody actuator to fit, took 3hrs. At one point thought old actuator was going to be refitted.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline wretch20vt
Re: Forge actuator awful fitment
« Reply #1 on: 20 April 2012, 19:50 »
what turbo? you have to send a very nice email to forge and they send you 3 different brackets
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 20 April 2012, 20:32 »
yup I got lucky as did Hulmie but quite a few people have had to get replacement brackets from Forge, it's not their fault as Borg Warner kept changing the thread locations depending on year/model
Offline shaft69
« Reply #3 on: 21 April 2012, 13:15 »
Ko3s fitted now but a lot of messing about, I'll ring them Monday or email them.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Chris.
« Reply #4 on: 22 April 2012, 13:48 »
Forge have about 3 or 4 different brackets for the k03's.
Should have rang them and explained and they would have sent out the others for you to fit.  I cant see them taking back a mullered bracket tbh.
Click For Build Thread
Offline shaft69
« Reply #5 on: 22 April 2012, 15:13 »
Not mullered perfect size hole drilled, fitted now wouldn't take it off again anyway. Why 3 different brackets turbo not changed?
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline wretch20vt
« Reply #6 on: 22 April 2012, 15:33 »
wazzer explains in his comment
Offline shaft69
« Reply #7 on: 22 April 2012, 16:56 »
Fitted now so all is good.
184 Wallgate, Wigan
WN3 4AL
07966492823.
